PostPosted: Wed Feb 17, 2021 3:09 am
I found these in a random box and not quite sure where to place them.
Thanks!
1 Front
1 Back
2
3
4
5
6
PostPosted: Wed Feb 17, 2021 11:31 am
Here's my guess:
1) Green Fiber with Metal or Apple CPU
2) Low Grade Peripheral
3) High Grade Peripheral; if it came out of a laptop, it would probably go as a Laptop Motherboard
4) Low Grade Peripheral
5) High Grade Peripheral
6) High Grade Peripheral
PostPosted: Thu Feb 18, 2021 1:33 am
Its actually a daughter board from an IMAC Motherboard. Its a weird one.
PostPosted: Thu Feb 18, 2021 1:39 am
I would still go with High Grade Peripheral.
PostPosted: Fri Feb 19, 2021 6:30 pm
Now on number 4 say he takes the transformers and the steel off would it get high periph?
PostPosted: Fri Feb 19, 2021 8:40 pm
I would think it would still be Low Grade Peripheral. But wait for Lostinlodos to reply.
PostPosted: Wed Feb 24, 2021 7:48 pm
1 Apple CPU
2 Low Grade Peripheral
3 High Grade Peripheral
4 low peripheral, re MVPvlad: no
5 Low Grade Peripheral Metal, plastic weights way beyond 6 ICs
6 High Grade Peripheral
PostPosted: Sun Feb 28, 2021 3:02 pm
Out of curiousity, If i found it within reason to remove the plastic and metal on boards like this, would this be considered high Peripheral?
PostPosted: Sun Feb 28, 2021 4:24 pm
Sort of.
I’ve dealt with scraping a few similar ultra condensed boards.
This is a glitch in the matrix.
The more compact a board is the more valuable the weight.
Here the board still kept the full port complex. Which is also uncommon in reduction.
The plastic port cover comes in two designs. The first being worth trying to remove. A piece attached to the board via 4 plastic legs about half the height of the ports. A second piece is then clamshell hitch snapped into place, forming the top half. Often glued in. Occasionally also or otherwise heat melted shut. Look for a seam half way up that goes 3/4 or all the way around. A pair of large slip jaws and some finesse and these snap open. Then some wiggling on the under side of the ports with a screw driver or heavy gage knife will pry the bottom half up enough to cut the legs and slide the plastic off.
The other method is is a single formed case shell moulded over and into the ports. The ports are installed with steel casing. The plastic is then formed over the ports. Here you need to remove the entire port complex. That generally reduces the board weight so much it’s not worth the effort.
In both cases the board would upgrade to high peripheral with the network ports removed or freed.
Again this is a fluke board. The vast majority of networking boards are high peripheral or higher.
