It is currently Sat Aug 01, 2026 8:59 pm
 Post subject: Telecom Boards
PostPosted: Thu Mar 25, 2021 11:43 pm
In light of the new peripheral grades, I'm hoping to get an opinion on these boards.
1 and 2: Siemens WAP, includes two large(ish) gold-fingered WiFi cards. Do those two cards make a difference in the grade, or should I remove them?
3. POE board: I'm guessing fairly low grade, def. not telecom, probably not even peripheral
4. This board is a bunch of small transformers under metal covers.
5. Not sure if this one would qualify for backplane or not.
I realize the photos are going to be in reverse order.
Thanks for the help!
 Post subject: Re: Telecom Boards
PostPosted: Fri Mar 26, 2021 3:39 pm
Here's my guess:
5) Low Grade Peripheral; could go higher.
4) Midgrade; there is a chance that this could be upgraded to Low Grade Peripheral.
3) Low Grade Peripheral
1 & 2) High Grade Peripheral; definitely remove the cards since they will go as Clean Gold Finger Cards.
Wait for Lostinlodos to give you definite answers.
PostPosted: Sat Mar 27, 2021 12:32 pm
Thanks!
PostPosted: Fri Apr 30, 2021 2:43 pm
5 is Backplane and 3 is High Grade Peripheral.
