 Post subject: Another Round to ID 4
PostPosted: Tue Mar 30, 2021 11:11 am
Various components we want to get rid of.
C.
File comment: I expect C, E, G, L and M are IC chips. K should be a 286/386 chip. A, B, and I have gold pins. The rest may be trash, but worth asking.
PostPosted: Tue Mar 30, 2021 11:26 pm
A. Gold Connector end
B. Backplane (???)
C, G, H, L, M. Definitely IC chips
E. Probably IC chips (not sure exactly what I'm looking at so can't be sure)
F, J. Not ICs but not sure what they are/what category it would fall under.
D. Crystal Oscillator (I think) not sure what category.
I. Plastic with some metal pins (???)
K. I think your guess is probably right, I've never gotten to deal with any of these myself.
PostPosted: Wed Mar 31, 2021 10:09 am
K should definitely be 386/486. I'm not sure about the others. We'll have to wait for Lostinlodos.
PostPosted: Fri Apr 16, 2021 2:55 pm
Bump.
PostPosted: Wed Apr 21, 2021 10:14 am
Notes on the pic below.
File comment: Based on previous post-Hoping this closer pic helps
A-I will add to Connector Ends
B-Seems to be some gold or goldish material.
F-?
D-?
I-Closer shot of the "goldish" pins
L-8086 chips. Top one has a gold top, but not the pins
M-8088. I wasn't sure if there was anything special about them. I assume IC Chip.
I am guessing that D, F and I are headed to the trash, but worth asking.
C.
PostPosted: Tue Apr 27, 2021 3:13 pm
Still checking with Chris on this post.
PostPosted: Wed May 05, 2021 4:57 pm
Chris says:
Boardsort wrote:
A = Connector End
B = Clean gold finger if plastic removed otherwise they would pay 1/2 price as fingers.
D = No Buy
F = No Buy
I = Connector Ends
L = Gold one is LSI Cpu; black one is an IC chip
M = IC chip
PostPosted: Wed May 05, 2021 10:30 pm
On the stuff that doesn't have a buy category, if it's something that came off a board (which I'm assuming they did) I will usually throw it in with my low or midgrade boards (depending on what it is). I don't normally get individual components and when I do it's normally because it fell off a board. Of course if it's more than a couple pieces here and there, probably shouldn't unless someone else can confirm Boardsort or whoever else you sell to is okay with it.
PostPosted: Thu May 06, 2021 9:08 am
Sorted. Thanks.
C.
