PostPosted: Fri Apr 02, 2021 7:01 pm
The first board is from a 1242ag. The pair of boards are from an 1141. Some parts are covered in metal and I pried it off of one of each board, just to see what was below. Since the metal is soldered down I will NOT be removing it.
File comment: 1242 top and bottom with metal
File comment: 1242 top metal removed
File comment: 1242 bottom metal removed
File comment: 1141 top and bottom with metal
File comment: 1141 top metal removed
File comment: 1141 bottom metal removed
PostPosted: Fri Apr 16, 2021 2:11 pm
Here's my guess:
1242 with metal: High Grade Peripheral
1242 without metal: High Grade Peripheral
1141 with metal: Both Low Grade Peripheral
1141 without metal: Both High Grade Peripheral
PostPosted: Fri Apr 16, 2021 6:47 pm
I didn't get any response for a long time so I ended up emailing Chris. He said "I would buy those as Telecom High Grade".
PostPosted: Fri Apr 16, 2021 8:26 pm
I've sent Chris quite a few emails and it seems (as in your case) that he grades boards higher than what they're graded as on the forum. So I tend to send an email to Chris as well as posting on the forum. And sorry about not responding sooner. I've been pretty busy for the last two weeks and haven't had the time to sit at my computer for two hours and catch up on 30+ posts.
PostPosted: Sat Apr 17, 2021 8:18 pm
No apology needed, thanks for your help
