It is currently Thu Aug 06, 2026 5:06 am
 Post subject: Need help grading
PostPosted: Thu Apr 22, 2021 10:34 am
Are these worth sending in?
 Post subject: Re: Need help grading
PostPosted: Thu Apr 22, 2021 5:59 pm
Here's my guess:
1st Picture: All Midgrade
2nd Picture: Low Grade Peripheral/Midgrade/Midgrade/Midgrade/Midgrade
Midgrade/Midgrade/Low Grade Peripheral/Midgrade
Midgrade
3rd Picture: Both High Grade Peripheral
4th Picture: If you took off those heat sinks, they could probably go as High Grade Peripheral.
5th Picture: High Grade Telecom/Low Grade Telecom/Low Grade Telecom
High Grade Telecom/High Grade Telecom/High Grade Telecom
6th Picture: Backplane/Low Grade/Low Grade
7th Picture: It appears that three of those are DVR's. DVR's should have a High Grade Peripheral mainboard and a lot of them even have hard drives. They are pretty easy to take apart. There is also a router in this picture. They also usually have a High Grade Peripheral mainboard and are easy to get apart. As is, the DVR's would Cable/DVR Box With Hard Drive or Cable/DVR Box Without Hard Drive. The router would go in the Small Take Apart category.
Midgrade and Low Grade Boards aren't usually worth sending. Peripheral boards and above are usually profitable to ship.
