It is currently Mon Mar 23, 2026 7:07 am
PostPosted: Thu Apr 22, 2021 10:41 am
Just trying to see what hand scanner/guts are categorized as? Have about 75 of them. Number pad only on scanner
PostPosted: Thu Apr 22, 2021 5:38 pm
Here's my guess:
1) I'm not sure what that would go as since I don't think it's the kind listed in the Payout Rates
2) High Grade Peripheral; remove the battery.
3) Low Grade
4) Low Grade Peripheral
5) That appears to be cast aluminum, which with all the extra stuff on it, would probably go as Dirty Aluminum.
6) Mixed Wire
7) Low Grade Peripheral
PostPosted: Fri Apr 23, 2021 12:39 pm
Ok. Thanks. Just wondering if there's any thing of value for cds, hard discs, floppy discs or zip discs? Also have keyboard e boards and mouse e boards for what category? Boards 2&3 are keyboards. Some of the boards are brown on one side.
PostPosted: Fri Apr 23, 2021 2:16 pm
I'm pretty sure CD's, floppy discs and zip discs don't really have any scrap value.
Boards that are brown on one or both sides are usually Low Grade. There are exceptions of course. Mouse boards went as Midgrade but with the Low Grade Peripheral category, I think a good amount of them will fall in to that category. I'm not sure on keyboard boards though.
The three boards in this picture appear to have all the components on the back side. If that is the case, I'll need to see the other side of them.
PostPosted: Fri Apr 23, 2021 2:41 pm
Sorry forgot to add second pic.
PostPosted: Fri Apr 23, 2021 3:36 pm
The keyboard boards at one point (before the peripheral split) were able to go into peripheral depending on what was on the board. I think the fingers and the bump IC are what needs to be there but I'm not 100% sure. Should be safe in low peripheral now.
PostPosted: Fri Apr 23, 2021 3:57 pm
Here's my guess:
1) Low Grade
2) Low Grade
3) Low Grade Peripheral
