 Post subject: 2 boards
PostPosted: Fri Apr 30, 2021 1:45 pm
Thanks
 Post subject: Re: 2 boards
PostPosted: Fri Apr 30, 2021 2:34 pm
I would say High Grade Peripheral for the big board and Midgrade for the small board.
PostPosted: Fri Apr 30, 2021 8:13 pm
I thought the same as what ccussins said but then I clicked on the image. If those are ICs on the smaller board it should be at least low peripheral.
But ccussins has more experience with this so I defer to him.
PostPosted: Fri Apr 30, 2021 8:22 pm
I agree. I looked at the picture again and those do seem to be little IC's. But I'll check with Chris to be sure. I should get a response on Monday.
PostPosted: Wed May 05, 2021 4:52 pm
Chris says:
Boardsort wrote:
I would take that small one as High Grade Peripheral if the mounting stud was removed from the center of the board.
PostPosted: Wed May 05, 2021 6:51 pm
Also, don't forget to remove the battery.
