It is currently Thu Jul 30, 2026 7:20 pm
 Post subject: Help with board ID
PostPosted: Wed May 05, 2021 6:03 pm
Is this low or high grade telco
Here to learn and make some $$
 Post subject: Re: Help with board ID
PostPosted: Wed May 05, 2021 6:49 pm
I would say Low Grade Telecom.
PostPosted: Wed May 05, 2021 8:38 pm
Anything I can do to make high telco
PostPosted: Wed May 05, 2021 9:03 pm
Not that I can see but I'm not completely sure on this one so I'm double checking with Chris (the guy in charge of Boardsort).
PostPosted: Tue May 11, 2021 9:41 am
Chris says:
Boardsort wrote:
Is the circled black part metal?
If so, you will have to remove it and then this board can go High Grade Telecom.
PostPosted: Tue May 11, 2021 8:40 pm
ccussins, If magnet does not stick to it I can leave, Correct? I ask for knowledge I have already removed
PostPosted: Tue May 11, 2021 8:56 pm
If you can verify it's plastic, than you can leave it on. It could be aluminum, which isn't magnetic.
PostPosted: Tue May 11, 2021 9:48 pm
Yep! it was aluminum
Thanks for clarification
