It is currently Tue Jul 28, 2026 12:04 am
 Post subject: Grade of the boards?
PostPosted: Fri May 07, 2021 11:14 am
Hello
Are these high grade Tel a com boards?
I have about 100 pounds and would like to drop them off.
Most are from Cisco Catalyst 3550 Series Switches.
Any value in the power supply for the switches?
Thank You
Jim
 Post subject: Re: Grade of the boards?
PostPosted: Fri May 07, 2021 12:37 pm
The power supply board would be a Low Grade Board. The green 15" x 17" board would be High Grade Telecom. I would need to see the populated side of the board in pictures tel Board6 and tel Board7 to make a accurate grading of that board.
PostPosted: Fri May 07, 2021 1:13 pm
Low grade
Probably high telco. Depending on rest of the board
Can’t tell from photo
Can’t tell from photos
Low peripheral
High telco
PostPosted: Fri May 07, 2021 2:06 pm
I'm pretty sure that tel Board, tel Board1, and tel Board2 are pictures of the same board.
PostPosted: Fri May 07, 2021 2:43 pm
They are the same, tel Board at the bottom is also a pic of it.
Should I remove the perforated boxes at the top of the board?
Thanks
Jim
PostPosted: Fri May 07, 2021 2:46 pm
laststand@sisna.com wrote:
Hello
Thank You
Jim
PostPosted: Fri May 07, 2021 3:05 pm
This is the other side of board 6 and 7.
Then I'm pretty sure it would be Low Grade Telecom.
No. If you removed them, they would probably go as Connector Ends. $1.00lb vs. $5.75. Leaving them on adds to your High Grade Telecom weight.
