It is currently Fri Sep 11, 2026 11:35 pm
 Post subject: silver plated brass
PostPosted: Wed May 12, 2021 7:31 pm
Have to ask if the bars from these contacts after the silver button is removed would fit in the silver plated brass category.
Or would there be a different price for these as they are with the contact button left on.
I have over 20 lbs.
TY
Joe
still looking for photo gallery of cpu's
 Post subject: Re: silver plated brass
PostPosted: Wed May 12, 2021 9:33 pm
Can’t answer your question regarding the silver plated electrical brass. And those look to be silver plated copper by the way. At least all the ones I’ve dealt with.
I would also imagine the silver on those electrical components is nowhere near as thick as what one would find on actual silver plated brass.
But, if you click on Payout Rates in the upper right corner if not signed in.
Left of top center if logged in.
Then scroll down to CPUs
Then click on each type of CPU listed.
A picture will pop up with an image or two of the CPU in question.
If you’re looking for the payout rates for the CPUs that BoardSort buys at a significantly greater value than scrap rate, you have to be signed or logged in to the site.
Those are listed by the Mfgr’s name and part number stamped on the CPU. Not certain if there’s photos of those or not though.
Hope this helps.
RFIII
PostPosted: Wed May 12, 2021 10:25 pm
Silver plated copper and brass can go together.
These look to qualify. But I can’t be sure by the photo. Nickel plate and tin plate are also common.
