It is currently Mon Jul 27, 2026 1:12 pm
 Post subject: IC Chips
PostPosted: Fri May 21, 2021 9:45 am
The picture shows socketed chips, does the category also include the ones you have to cut off? Also aren’t packs still considered IC’s? Thanks
 Post subject: Re: IC Chips
PostPosted: Fri May 21, 2021 4:44 pm
Sorry! Flat packs*
PostPosted: Fri May 21, 2021 5:37 pm
Flat packs have their own categories.
Technically everything under the flatpack heading is IC chips.
PostPosted: Fri May 21, 2021 5:44 pm
Ao the IC’s you have to cut off are good??
PostPosted: Fri May 21, 2021 6:05 pm
Depends on what you mean by cut off. Not everything on a board that /looks/ like and IC actually is one. There’s also resistors, capacitors, transformers, fuses, relays, ….
But yes, BoardSort buys any and all ICs under the correct category.
PostPosted: Mon May 24, 2021 9:37 pm
Im talking about the ones that have ic and a number on the board itself Ic’s have icxxx or a U correct?
PostPosted: Sat May 29, 2021 9:43 pm
Generally, yes. There are always exceptions to every rule and different manufacturers use different labels on their boards.
PostPosted: Sat May 29, 2021 9:52 pm
I will cautiously say probably.
The official answer is I can’t tell you without a photo.
