It is currently Sun Aug 02, 2026 8:56 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed May 05, 2021 11:01 pm
On group 14, Chris said: 1 and 2 are Low Grade Peripheral and 3 is High Grade Peripheral. This is the group where he gave me the "word of advice".
PostPosted: Wed May 05, 2021 11:04 pm
On group 15, Chris said: 1 and 2 are Low Grade Peripheral and the rest are High Grade Peripheral
PostPosted: Wed May 05, 2021 11:09 pm
So now that it almost all said and done, I only have 7.2oz of boards that were graded as Low Grade Peripheral out of my whole 22lb peripheral box. I'm still checking with Chris about the boards pictured below. They were graded as Peripheral but now I'm pretty sure that they will be Connector Ends.
PostPosted: Fri May 14, 2021 2:36 pm
Chris said they were Connector Ends.
PostPosted: Sat Jun 05, 2021 2:11 pm
This is a great post, helps out a lot, Thanks.
PostPosted: Mon Jun 07, 2021 10:28 am
I am a little perplexed by grouping 10. More to the point the two boards in the middle with the rows of black IC chips running across them. I don't understand why they are low grade peripheral. Can someone please elaborate? Thanks in advance.
PostPosted: Mon Jun 07, 2021 10:32 am
Chris graded them as Low Grade Peripheral because of all the heavy "junk" (transformers, capacitors) that they had. I was pretty certain that without all that stuff, they would be graded as High Grade Peripheral especially since they had all those IC's. So I removed the "junk" and put the boards in my High Grade Peripheral box (forgot to mention this).
PostPosted: Mon Jun 07, 2021 10:49 am
Here's another group of boards that I pulled out of my Midgrade box. I had went through my Midgrade box and pulled out all the ones that I thought had a chance at getting Low Grade Peripheral. Chris said that 1 was Low Grade and the rest were Low Grade Peripheral.
PostPosted: Sat Jun 26, 2021 5:32 pm
Here are some more boards that I asked Chris about. He said they were both Low Grade Peripheral.
PostPosted: Tue Jul 27, 2021 10:19 am
I checked with Chris on this board wondering if it could get higher than High Grade Peripheral with the two metal boxes removed. He said it was High Grade Peripheral with no upgrade ability.
