It is currently Fri Sep 25, 2026 12:28 am
 Post subject: Help with board grade
PostPosted: Thu Jun 10, 2021 9:44 pm
Please grade these boards
PostPosted: Thu Jun 10, 2021 11:52 pm
The board with the ceramic chip should definitely be High Grade Peripheral. I think you can remove the fingers and still get the grade. The other board is either High Grade Peripheral or Low Grade Telecom, not sure which. I'll check with Chris.
PostPosted: Sat Jun 12, 2021 9:16 pm
I think ccussins might have meant high telco on the ceramic chip board.
PostPosted: Sat Jun 12, 2021 9:26 pm
Yeah, that's what I meant to say. I'm just so used to typing "High Grade Peripheral". :)
PostPosted: Sat Jun 12, 2021 11:10 pm
Thank you guys! Ccussins I hope all is well enjoy your time wit family
PostPosted: Sat Jun 26, 2021 10:41 am
Chris said:
Boardsort wrote:
Technically, you are not to remove any gold from a board without it being a downgrade, particularly on such a higher paying grade as a Gold Cap Chip Board, which this is.
The other board would be Low Telecom as is, but the green battery must be removed. If the fingers are trimmed it, would be High Peripheral, again without battery.
PostPosted: Sat Jun 26, 2021 4:58 pm
The green cylinder in question looks to be a capacitor but if you can't confirm that then better to remove it as Chris advised.
PostPosted: Mon Jun 28, 2021 1:55 pm
Green capacitor removed, Thank you
