It is currently Wed Jul 29, 2026 1:43 pm
PostPosted: Tue Jun 15, 2021 5:38 pm
Should I be cleaning off extra Steel or just heat sinks ? Thanks
PostPosted: Tue Jun 15, 2021 11:29 pm
There is a .30c per lb difference if you don't take them off. So ya, if I were you, I would take them off. :)
PostPosted: Wed Jun 16, 2021 12:01 pm
I did the same with a previous set of boards. I removed the heat sinks and brackets.
I have the brackets adding up in a misc. steel box so I can take to my local metal recycle station when it adds up.
Not sure what to do with the heat sinks though.
PostPosted: Wed Jun 16, 2021 1:36 pm
Thanks for the info the Heat sinks are usually aluminum they usually are 6061 or 6063 grade of aluminum should bring around fifty cents a pound ,,
PostPosted: Wed Jun 16, 2021 2:41 pm
Ah Aluminum, true. That's another box for the local recycle station. Bet the Copper ones are more obvious to notice.
