 Post subject: Grade help 2
PostPosted: Fri Jun 18, 2021 1:45 pm
Unsure about these boards. Please note that although the "silver" connectors add a bit of weight, they each have a nice big gold plated connector inside them.
 Post subject: Re: Grade help 2
PostPosted: Fri Jun 18, 2021 8:55 pm
I found a similar board recently, those connectors add a lot of weight.
I'm leaning toward midgrade, but I could see it making it in low peripheral. Probably should wait and see if someone else has a better idea than me on this one.
PostPosted: Tue Jun 22, 2021 11:13 am
Okay, so if that's the case, then I should just simply remove the metal connectors, put them in with my connector ends and make the boards H. G. periph?
PostPosted: Mon Jun 28, 2021 2:57 pm
Both Midgrade as is. If you remove the metal connectors on the top one, it can go Low Grade Peripheral. The other board is Midgrade regardless.
