It is currently Thu Sep 24, 2026 9:21 pm
 Post subject: Grade help 1
PostPosted: Fri Jun 18, 2021 1:39 pm
The top board I am pretty sure is High G. Periph +. The second board I have no idea. Is it low tele? Or lower? All these pics are of the same 2 board types, front and back.
 Post subject: Re: Grade help 1
PostPosted: Fri Jun 18, 2021 8:52 pm
I think high peripheral is right on the top one.
As is the lower board looks midgrade to me. Pull the wire clamp (proper name???) out of that socket and I think you'll be at low peripheral.
The wire clamp will either be brass/copper and plastic or steel and brass/copper and plastic. Run a magnetic over it to know which.
PostPosted: Sat Jun 26, 2021 5:47 pm
I agree. The top board is definitely High Grade Peripheral. And I agree that if you removed the wire clamp on the other board, you would be safe at Low Grade Peripheral.
