It is currently Sat Nov 07, 2026 12:30 pm
 Post subject: needs more grades
PostPosted: Mon Mar 24, 2014 7:18 pm
most of these i would think are low-grade but never hurts to be sure
 Post subject: Re: needs more grades
PostPosted: Mon Mar 24, 2014 9:25 pm
The boards that are brown on one side are definitely low-grade. If you want, remove any IC chips on these boards and sell them separately.
The green boards you have that have none to very few IC chips are mid-grade. Sell as-is.
The one board you have that appears to be a PCMCIA card may go as peripheral. You may get more if it's a wireless card. Remove the metal shields or heatsinks on the one side if possible.
PostPosted: Mon Mar 24, 2014 9:39 pm
ok thanks just what i figured .and yes..it indeed is a wireless card.
PostPosted: Tue Mar 25, 2014 1:34 am
few more
PostPosted: Wed Mar 26, 2014 8:42 pm
few more
PostPosted: Fri Mar 28, 2014 11:12 am
kgryczan is correct with your first round of pictures, except that wireless board with the shield is only going to bring Peripheral Grade, there isn't enough population to grade higher. You can keep the shield on however.
All the other pictures in that first round are Midgrade is Green, Low Grade if Brown.
In your second round of pictures all of those boards are going to be Peripheral Grade.
Thanks for the look!
