 Post subject: Diamond Box 18
PostPosted: Fri Jun 25, 2021 2:13 pm
Looking to get clarification on how to classify these prior to shipment.
Thank you in advance!
C.
File comment: Back Side of above
 Post subject: Re: Diamond Box 18
PostPosted: Sat Jul 03, 2021 9:26 am
A) Low Grade Gold Finger Card. Remove the metal box and it will be Clean Gold Finger Card.
B) Low Grade
C) Connector End
D) High Grade Peripheral
PostPosted: Tue Jul 06, 2021 9:07 am
Sorted. I will make an attempt to remove the metal box, but there is a board inside that. Both pieces, same designation?
C.
PostPosted: Tue Jul 06, 2021 9:53 am
If you removed the metal box, it would go as Low Grade. If you were able to separate the board from the box, the board could probably go as High Grade Peripheral.
PostPosted: Tue Jul 06, 2021 2:17 pm
Metal Shield removed...Yes, there was a struggle. Final Answer?
C.
PostPosted: Tue Jul 06, 2021 5:46 pm
The card is now a Clean Gold Finger Card and the little board is High Grade Peripheral.
PostPosted: Wed Jul 07, 2021 8:11 am
Sorted.
C.
