It is currently Sun Sep 27, 2026 12:52 pm
 Post subject: 7/20/21 grade help 3
PostPosted: Tue Jul 20, 2021 10:34 am
More boards. Same 2 boards front and back.
 Post subject: Re: 7/20/21 grade help 3
PostPosted: Tue Jul 20, 2021 1:45 pm
In the attached picture, board 1 was graded as Low Grade. That would make this first board Low Grade as well. The second board should be good for High Grade Peripheral if you remove those two big components hanging off the left side of the board. It would probably be a good idea to see if you could rip off those two metal structures, too.
PostPosted: Wed Jul 21, 2021 12:34 pm
Those 2 big components hanging off the side are actually IC chip. Should I still remove them? I will see if I can get the metal off the board itself. Thank you.
PostPosted: Wed Jul 21, 2021 12:40 pm
If they're IC chips, then you should leave them on.
