It is currently Wed Jul 29, 2026 9:43 am
 Post subject: Any suggestions
PostPosted: Thu Jul 22, 2021 10:32 pm
Third board:
These are front and back of identical boards.
I cant quite tell if the silver colored cap is part of the chip underneath it but it is soldered to the board. I cant slid a screw driver under it to pry it off.
Second board:
Can I snip the gold wire (antenna) and pull the charging contacts with out down grading the board?
First board:
I am pulling these charging pins do I need to try and get the springs out?
 Post subject: Re: Any suggestions
PostPosted: Fri Jul 23, 2021 9:47 pm
I went ahead and pulled the antenna wire and the antenna jacks on the second boards. I still cant figure out what to do with those silver colored caps(they are magnetic).
