It is currently Mon Aug 03, 2026 2:24 pm
 Post subject: High peripheral?
PostPosted: Thu Jul 29, 2021 4:14 pm
All of the pictures are of the same board, just different views to show the IC's in the metal box. Is this just high peripheral or anything higher? What if I remove the coax metal box? Also, the pins in the black connector appear to be gold plated. Nearly half the weight is actually in the higher IC population side as well (not sure if that makes any difference).
 Post subject: Re: High peripheral?
PostPosted: Thu Jul 29, 2021 6:47 pm
Should be high peripheral
PostPosted: Fri Jul 30, 2021 8:19 am
If you removed the metal coax boxes the boards would still be High Grade Peripheral.
PostPosted: Fri Jul 30, 2021 3:29 pm
I appreciate the confirmation.
