It is currently Thu Aug 27, 2026 8:45 pm
PostPosted: Sun Jul 05, 2015 10:36 am
is this a slot processor or a big gold finger card.?..it has a cpu
PostPosted: Sun Jul 05, 2015 11:04 am
It is only a gold finger card.
PostPosted: Sun Jul 05, 2015 11:44 am
Yep. Gold finger card. It's a video card.
PostPosted: Sun Jul 05, 2015 11:54 am
thanks...i was hoping for slot...its heavy though
PostPosted: Sun Jul 05, 2015 12:14 pm
The reason slot processors are as high as they are is because they contain more of the chipset that is normally on the board. They have a heavy gold contact layer under the masking on the front and back (like mini/mainframe computer controllers) and the finger connection is almost 4x thicker and Has a better coverage by area.
PostPosted: Mon Jul 06, 2015 12:32 pm
do all slot processors look the same?..i have a few from different brand computers and they are all identical...and yes the gold fingers on bottom are thicker...you are right about thatlow dos
PostPosted: Mon Jul 06, 2015 12:57 pm
Like everything in computers there are exceptions-especially because "slot proceasors " are not industrially standardised but yes most are identical in appearance.
Most are long rectangles
See 1
Xeon and opteron are almost squared in shape.
See 2
Via had one that was a v shape like to short rectangles at a 75° angle (never made sense to me beyond v for via).
Some early acorn units in box form had a riser cpu that is technically a slot processor though it predates the term and Boardsort took it from me as telco. Probably to much surface area but i digress...!
So yes MOST slot proceasors look similar. And the ones that don't probably Go in another category.
PostPosted: Mon Jul 06, 2015 2:32 pm
thanks...a picture is worth a thousand words...good info
PostPosted: Wed Jul 08, 2015 12:58 pm
heres another gold finger card..the gold is really thick...had a heatsink glued to it...is that silver too?
PostPosted: Wed Jul 08, 2015 1:09 pm
it had an aluminum heatsink glued to the back where the silver is
