It is currently Thu Aug 06, 2026 5:21 am
 Post subject: Any ideas on these?
PostPosted: Sat Jul 24, 2021 9:55 pm
These are front and back in same set.
 Post subject: Re: Any ideas on these?
PostPosted: Sat Jul 24, 2021 11:11 pm
1. Everything about that makes me think cell phone. I googled the name on the board...it's just a transmitter so not sure. I'm thinking it may be high telco.
2. Sounds right.
3. At least low telco, maybe bordering high.
4. That looks like a solid state drive of some sort which would normally be high telco.
PostPosted: Sun Jul 25, 2021 9:43 am
Maybe this will help?
The first boards are out of L3 communications voice link.
The fourth boards are out ScanDisk L3 mobile vision flashback2 boot image.
PostPosted: Sun Jul 25, 2021 10:36 am
Knowing the compact flash card is the last one I found a similar board with only two ICs that Lostinlodos graded as peripheral (presplit?) so I'd go high peripheral like you initially thought.
You're at a wall with my knowledge so hopefully ccussins gets a chance to see those boards.
PostPosted: Fri Jul 30, 2021 4:19 pm
I'm guessing High Grade Peripheral on boards 1 and 3. 2 would be Low Grade Peripheral as is and High Grade Peripheral with the junk removed (like you thought). I agree with Marked141 on 4. I am checking with Chris to confirm, though.
PostPosted: Fri Jul 30, 2021 10:05 pm
For some reason I was thinking flash cards were peripheral, but I am not sure enough to call it.
PostPosted: Fri Jul 30, 2021 10:46 pm
Chris said 2 is mid grade.
My guess is pull the transformers and capacitors and it will go low peripheral?
PostPosted: Tue Aug 03, 2021 11:34 am
That would be my guess but I would still check with Chris to be sure.
PostPosted: Wed Aug 04, 2021 11:48 am
1 and 3 are High Grade Peripheral. Still checking on the CompactFlash card.
PostPosted: Mon Aug 09, 2021 2:25 pm
The CompactFlash card is High Grade Peripheral.
