 Post subject: 08/08/21 grade 12
PostPosted: Sun Aug 08, 2021 5:21 pm
Same 2 boards front, back, close ups, and connector. Please grade.
 Post subject: Re: 08/08/21 grade 12
PostPosted: Mon Aug 09, 2021 4:51 pm
high peripheral
they might go low telco
PostPosted: Fri Aug 13, 2021 12:31 pm
I will check.
PostPosted: Tue Sep 07, 2021 4:49 pm
Boardsort wrote:
The top board (the one that has the Axis BGA) can go High Grade Telecom as is and so can the other board if you knock off those two big steel connectors; otherwise Low Grade Telecom as is.
