It is currently Thu Jul 30, 2026 11:55 pm
 Post subject: Grade PH 17-22
PostPosted: Mon Aug 23, 2021 12:48 pm
 Post subject: Re: Grade PH 17-22
PostPosted: Wed Aug 25, 2021 7:25 pm
Timekeeper is a clue that it is a battery to be removed see bright yellow box on #19
PostPosted: Thu Aug 26, 2021 10:19 am
Ph17 - unscrew and remove the 15pin D connector with the short tab of copper ribbon cable on it. Throw connector in gold pin connector pile if pins are gold plated.
Ph18 - snip off that pink barrel shaped battery.
Ph21- pry out that pink button battery. The Qualcomm housing and the wireless card inside should be removed as well. The wireless card may have it’s own grade or be the same grade as the board it came from.
Also remove the wire bale that secures the Delkin Devices card. Remove and open up the Delkin Devices card. Another pcbd with its own grade should be inside as well.
Inspect your boards for batteries, connectors, easily removed metal housings etc. Batteries, if I’m not mistaken, can be cause for rejection.
Also, removing other boards however small from a mother board, larger board etc, can help you get a lil bit more money for your efforts.
Enjoy,
RustyFuryIII
PostPosted: Wed Sep 01, 2021 9:45 am
After doing what RustyFuryIII said, all these boards should be good for High Grade Peripheral.
