It is currently Sun Sep 27, 2026 8:13 pm
PostPosted: Thu Sep 16, 2021 12:04 am
Thanks for the Help!
1 (Im assuming these are all the same?)
PostPosted: Thu Sep 23, 2021 2:38 pm
Bump Bump. Anyone have any ideas? =D
Just wanna make sure I don't mix these in with something they're not.
PostPosted: Thu Sep 23, 2021 4:37 pm
IMHO, take this with big grain of salt as I am bumping through the new(to me) Hi / Lo variations.
You need to remove those AL rails
6 - need to remove, Large Caps, heat sinks, brass standoffs and then would think Perif Lo due to too much space
5 - really stripped all the value, prob only Perif Hi
4 - Telco Lo
3 - Telco Lo
2 - tough one if everything was left on, closer to telco hi, as is I would think telco lo, but IMO, too much board for the ICs that are there.
1 - I do not think all the same, L to R, T to B,
a - Telco Lo
b - Put ICs back, Telco Hi, borderline without, don't know how it would go
c - As is Telco Lo
d - See b
e - Telco Hi
f - Gold Cap
g - Def Telco, maybe hi??
Hope this helps, hope I got more right than wrong!
PostPosted: Fri Oct 01, 2021 12:02 pm
Thanks for the help!
PostPosted: Mon Oct 04, 2021 10:50 am
Chris says:
Boardsort wrote:
1) All High Grade Telecom except for the board that has a gold capped chip on it. That board is, of course, a Gold Capped Chip Board.
2) This board can squeak into High Grade Telecom.
3) Remove the silver connectors for Clean Gold Finger Card.
4) High Grade Peripheral
5) High Grade Peripheral
6) Midgrade as is and Low Grade Peripheral if the heatsinks, capacitors, and transformers are removed.
