It is currently Mon Sep 28, 2026 12:16 am
 Post subject: Odds and ends
PostPosted: Thu Sep 02, 2021 10:46 pm
A few of the more unique boards leftover from my otherwise complete cleanout of a local scrap yard :D If someone can give me their opinion on grade as is and best possible grade if anything is removed I'd appreciate it.
A) I think the aluminum could be removed easily enough but would end up with two boards, one with the connecting components one without. Gold pins and through holes on both boards.
B) Probably won't separate these, nice gold pins.
C) Pins in the port are gold all the way to the board, two IC chips and lots of weight that I'll probably cut off.
 Post subject: Re: Odds and ends
PostPosted: Tue Sep 07, 2021 10:59 pm
bump
:D
PostPosted: Mon Sep 13, 2021 10:21 am
C) Midgrade as is. If you remove all that junk from the board, you're probably safe at High Grade Peripheral.
B) I'm guessing Low Grade Peripheral but I'll check to be sure.
A) I would think it would be Midgrade either way. I just don't see how those few gold pins in the connectors are enough to go higher. I would separate the boards from the aluminum, and then cut the two green boards in half and throw the halves with the connectors on them in Connector Ends.
PostPosted: Fri Sep 17, 2021 2:27 pm
Chris says that B is High Grade Peripheral.
PostPosted: Fri Sep 17, 2021 3:01 pm
Thanks for the followup ccussins!
