 Post subject: Vintage board grading
PostPosted: Sun Sep 19, 2021 2:26 pm
Hello, I have several of these boards pulled from what seems to be a vintage dumb terminal (large housing consisting of a keyboard and CRT screen with no apparent I/O ports). There are 8 boards in this unit of three different types. All three types have gold-plated finger connectors.
Board #1 is all IC chips with a few caps and resistors.
Board #2 is similar to #1, but has some IC chips with gold legs
Board #3 has a few gold-capped ICs and others with gold legs. Has the label "Memory" on the upper corner"
Thanks!
File comment: Terminal board #3
File comment: Terminal board #2
File comment: Terminal board #1
PostPosted: Sun Sep 19, 2021 3:43 pm
So, terminal boards #1 and 2 are going to be at least CGF boards, might go as high as High grade tele. Terminal board # 3 is going to be a gold cap chip board. For verification I would wait on lost or ccussins to post a reply to this. Good luck brother and nice boards!
PostPosted: Sun Sep 19, 2021 9:04 pm
Based on similar boards I posted that Chris and Lost graded and cross referencing Lost's post on CPU/IC chips.
#2 Should have no problem going High Telco with the ceramic ICs with gold legs and gold fingers.
#1 I'm leaning High Telco but an opinion from ccussins would probably be good. The ceramic ICs with gold legs on #2 helped me go high telco there, but this board doesn't have that so may not make it, not sure a board like this would make it in the clean GFC category or not so could be as low as low telco.
#3 Easily Gold Capped Chip board.
~~edited to correct for my swapping board order~~
PostPosted: Sun Sep 19, 2021 10:11 pm
Thanks for all the input. Just for clarification, Board #1 does not have any chips with gold legs. They're all just regular IC chips.
PostPosted: Mon Sep 20, 2021 8:31 pm
Not OP, but just wondering, what grade would these boards get if you were to trim the gold fingers?
PostPosted: Mon Sep 20, 2021 9:31 pm
Apologies I double checked which was which twice and still switched them D:
PostPosted: Fri Sep 24, 2021 3:13 pm
Chris says that board 1 is High Grade Telecom.
PostPosted: Thu Sep 30, 2021 5:55 pm
Thanks for all the input!
