 Post subject: ID Assist Request 1
PostPosted: Mon Sep 13, 2021 4:58 pm
I have bulk of most of these but not sure of ID
 Post subject: Re: ID Assist Request 1
PostPosted: Sun Sep 19, 2021 6:09 am
You had asked in another post why no answers as to ID of these boards. While they appear to have gold pins and sufficient gold flash on posts, all components are either diodes or miniature. Most of us are familiar with the standard IC's and can make an accurate id based on that. But with the particular design of these, we don't see enough to evaluate. Some of these have the gold fingers, gold pins, and no excessive junk weight, so should go as high peripheral or better, but then it appears the board itself may be a drilled board, with no internal layers of conductive copper, so the board itself may lower the grade.
Since I hand deliver, I simply box the identical, label them as what I think, and let the dock crew put them in the official class at the receiving dock. If you are shipping, you don't have this option.
PostPosted: Sun Sep 19, 2021 11:34 pm
Sorry for the delayed response. I have been busy the last few days.
1) High Grade Peripheral
2) Midgrade
3) Low Grade Peripheral
4) Low Grade Peripheral as is; if you cut/break off the blank section, it can go High Grade Peripheral.
5) High Grade Peripheral
6) High Grade Peripheral if you remove the component that has the number 9100-4858-1 on it.
7) High Grade Peripheral
8) High Grade Peripheral
Note: Make sure you remove all wires and cables from boards.
I will check with Chris on these boards to make sure I'm not completely wrong here.
PostPosted: Thu Sep 23, 2021 7:11 pm
Thank you, very helpful!!
PostPosted: Fri Sep 24, 2021 2:25 pm
Chris said:
Boardsort wrote:
All High Grade Peripheral except for board 2 which is Midgrade. You don't have to remove the blank section on board 4 as it can go High Grade Peripheral as is. You should remove the component mentioned on board 6 though.
