It is currently Sat Sep 26, 2026 8:02 pm
 Post subject: 10 more boards | H
PostPosted: Mon Sep 27, 2021 2:27 pm
Thank You!
 Post subject: Re: 10 more boards | H
PostPosted: Mon Sep 27, 2021 8:07 pm
1. High telecom, remove the screws. I think you should be fine if you intend to trim the fingers.
2. Same #1
3. Same as #1
4. Low telecom
5. Low telecom
6. Backplane
7. Laptop mobo
8. High peripheral, remove the bracket
9. Small socket green mobo
10. Small socket green mobo
PostPosted: Wed Sep 29, 2021 7:27 am
Pic780 - remove the nuts & bolts
Pic778 - remove standoffs
Pic774 - Looks like a bunch of through board stand offs, if they are part of the board they stay. Typically they are all part of the same metal frame and should be pulled.
Pic771 - Last Pic - Remove connectors that have wire dangling, and remove the battery
