It is currently Thu Aug 06, 2026 4:24 am
 Post subject: Gold-cap chip boards
PostPosted: Thu Sep 30, 2021 8:09 pm
Do these boards have enough gold-capped chips to be considered "gold-cap chip boards", or would they just go as high-grade telco? They're all soldered on. Do the boards need to be primarily covered with chips to fall into that category?
Thanks!
 Post subject: Re: Gold-cap chip boards
PostPosted: Fri Oct 01, 2021 7:22 am
All boards considered gold cap, just takes one gold cap chip to elevate the board
PostPosted: Fri Oct 01, 2021 1:16 pm
Thanks!
PostPosted: Fri Oct 01, 2021 4:20 pm
I feel like I've seen a post regarding fiber sun chips with the gold cap being less valuable than other good caps, might be worth waiting to see if ccussins or someone can clarify.
I'll try and get back to this this evening and search the forum more if nobody else provides input beforehand.
PostPosted: Fri Oct 01, 2021 8:48 pm
This may be what I was remembering
viewtopic.php?f=4&t=18538&p=31730&hilit=sun+fiber+gold#p31730
The chip probably has no pins and therefore has less value. I don't know if the caps are enough to make up for the difference, probably need to contact Chris to be sure.
