I bought a small pallet lot of AllenBradley power supply at auction a few months ago. Each unit weighs about ten-fifteen pounds whole. It was quick work to strip on the outer case, aluminum on some, and recover the boards which is heavy with transformer and torsion coils and heavy aluminum. Since these models were approximately 20 years old, no demand was evident on ebay, for this particular model #. After removing the board, I was left with a transmission block, as pictured. While it has some copper and brass connectors, it didn't seem worth stripping, and I was about to toss them in the shred tin pile, when I noticed the gold pin connector sticking out of the plastic base. Also, another female connector sat on top. So I opened one. Nice little board, too good for shred at less than a dime a pound, so I opened all of them. Photos show sequence. The bottom plastic cover popped off easily with a single blow from a hammer. Then, I used an old thin bladed butcher knife as a "chisel" to cut the boards solder connections from the transmission block. Unfortunately, not much weight, and not a great value, but it is another pound or two into the next load, and I know what is hidden in the transmission block.
| Attachments: |
