It is currently Sun Mar 22, 2026 6:36 am
PostPosted: Mon Oct 25, 2021 1:11 pm
Need help identifying
PostPosted: Mon Oct 25, 2021 3:20 pm
Can you verify the color of the fingers? Is there anything in the back of the board?
PostPosted: Mon Oct 25, 2021 3:25 pm
Gold fingers better photo and back of it attached
PostPosted: Mon Oct 25, 2021 3:58 pm
There's basically nothing there except the gold fingers, I'm really not sure where to place it but I'd think high peripheral would be okay if the bracket is removed.
PostPosted: Mon Oct 25, 2021 5:58 pm
The main ic chip has been removed so this drops the grade of the board significantly.
Boardsort does not generally buy processed material, so I would remove the gold pin connector next to to the bracket (put with your gold pin connectors), and cut off the gold fingers. Then put it in your local yard's shred pile.
