It is currently Tue Aug 04, 2026 8:52 am
PostPosted: Tue Oct 26, 2021 1:32 pm
I have 3 versions of Cellular uplink cards used in security systems
How would this card be classified? They are all 3 1/2 by 3 inches in size.
PostPosted: Tue Oct 26, 2021 10:22 pm
1. You will need to remove the two metal cylinders (not sure what they are, capacitors?). High peripheral
2. High peripheral
3. High peripheral
Also, I suggest you to upload photos as separate images instead of as collages
PostPosted: Tue Oct 26, 2021 11:17 pm
Boardsort doesn't buy SIM cards at present so make sure you pull those out. Do remove the shields. Based on similar boards I've sent I would think 1 and 2 have a chance of going low telco if you remove the wire clamps. 3, I think you need to remove the wire clamps to get high peripheral.
PostPosted: Wed Oct 27, 2021 10:59 am
Thank you for your input. As an example it would be best to submit the board from the first set of pictures as shown below.
I do have a question, if it is better to pull off the two Capacitors, SIM Chip and the wire connectors, should I leave the toggle switches on the board and the antenna connector?
PostPosted: Wed Oct 27, 2021 3:59 pm
To your question, the toggle and antennae connector should stay.
Seeing the better photo, I think your definitely on the higher end of high peripheral for that particular board but I'm still not 100% it'll make low telco. If you have lots of that board to go through I'd just leave the extraneous material on and go high peripheral with them. Unless ccussins or someone can verify it making low telco of course.
PostPosted: Wed Oct 27, 2021 6:36 pm
I have quite a few of these things and getting a few more everyday or so. It was pretty easy to remove the capacitors and wire attachments so if it would make low telco I would probably remove what ever was needed. Never sent anything into Boardsort before but I am thinking the shipping is not going to be cheap. Really appreciated your thoughts on these boards
