PostPosted: Tue Nov 02, 2021 11:35 am
I was wondering if someone could help me with Classifying these boards. They are from an XBox 360
PostPosted: Tue Nov 02, 2021 1:45 pm
xbox 360 Board is Periphial
The remaining ?
PostPosted: Tue Nov 02, 2021 2:33 pm
Canadian E waster, I believe they're all from an Xbox
:D
1) high peripheral
2) I think there's enough there to go high peripheral
3-4)
Square) high peripheral (possibly low telco see if one of the more experienced users can verify or contact Chris directly)
Goofy L) remove the shield and if the antennae (metal and plastic bit on the skinny leg) is steel go ahead and pull that off too. Should be at least high peripheral then (possibly higher, same suggestion as previous board)
