 Post subject: Please help ID 2
PostPosted: Thu Nov 18, 2021 4:43 pm
Please help grade these boards. If they have the same letter they are the same board, just flipped.
 Post subject: Re: Please help ID 2
PostPosted: Thu Nov 18, 2021 11:40 pm
A. Large socket motherboard
B. Gold finger card. The one on the bottom right is a slot processor.
C. Take off the shield and take a picture of it
D. First, you will need to separate the boards. The board on top is high peripheral if there isn't much on the other side of it. The board under it is a gold finger card with bracket as is, remove the bracket and handle and it will be high telecom.
PostPosted: Fri Nov 19, 2021 10:20 pm
A, I concur
The voltage regulators (B) should be high peripheral. The gold fingers bring the value up but not that much because of the rest of the board. Make sure there's no heatsinks on the back to get that grade. (lower right I agree slot processor)
C looks like a voltage regulator too. With the heatsink probably midgrade (possibly edging into low peripheral).
D may even have a battery inbetween the boards so definitely take apart.
