It is currently Mon Jul 27, 2026 7:43 pm
 Post subject: Connector Ends?
PostPosted: Sun Aug 08, 2021 1:50 pm
Just really getting started with BoardSort and am probably gonna fire a few questions out pretty quickly. My first question pertains to connector ends and what exactly qualifies as a “connector end”? Do both male AND female ends count or just the male end? Also, does this ONLY pertain to ends that have gold pins in them or do ends with brass, aluminum or tin also count? So confused right now
 Post subject: Re: Connector Ends?
PostPosted: Sun Aug 08, 2021 2:57 pm
Make and female.
Gold pin connectors.
Usb, dvi, hdmi, vga, sata, etc.
PostPosted: Sun Nov 28, 2021 11:35 am
Hello, I also am new here and was wondering if these ends are something Boardsort buys?I was also wondering about optical drive and hard drive write heads. See attached.
Regards
Neil
PostPosted: Sun Nov 28, 2021 4:15 pm
Top. Three of those would be connector ends with the wire cut off.
I don’t believe the smallest one is gold pin
My general suggestion for the disc laser modules is to toss the plastic ones into low peripheral and metal ones into midgrade.
You can do the same with disk arms. There’s some info on breaking this stuff down if you’re after certain things. Try searching for rhodium or laser.
But for the general public scrappers it’s more trouble than it’s worth
Remove the plastic backplate and the hard disk through connector is connector end.
PostPosted: Thu Jul 13, 2023 11:16 am
I just came across this searching for something else--can you clarify what you mean for the disk arms? I have a bunch of these and I've been waiting to see if it was worth the time to try to get the little rhodium heads off. I have removed the winding from all of them.
Specifically, is Chris buying these just as aluminum, or is there a category for them due to the tiny bit of rhodium and possible bit of gold?
PostPosted: Thu Jul 13, 2023 3:47 pm
The arm is the complete actuator arm. It has 1-6 heads (8 for enterprise drives).
The heads on the end have a tiny bit of rhodium in them. Totally clean and with the steel ring removed you’ll get aluminium rate. As a whole they are generally midgrade.
If you have a lot, dozens of pounds, I would email Chris. Depending on daily values he may or may not offer a higher rate.
Keep in mind the rhodium content is infinitesimal. The head itself fits inside the dot of the i in TNR font at 10 point.
Like many of the treasure hunts I’ve posted this is for a hobby refiner with much time to dedicate. Not a method for the masses to get rich.
