PostPosted: Thu Dec 02, 2021 2:21 pm
What category are these in?
Does anything need to be removed from these?
PostPosted: Fri Dec 03, 2021 11:06 am
That looks like a backplane board, but it seems to have two CPUs on it. If you can get a clearer close up picture of the CPUs that will help with identification.
PostPosted: Fri Dec 03, 2021 12:57 pm
After more research I found out that is a memory expansion board out of an IBM Power5 server. Too bad you didn't have the entire unit, they still have some resale value higher than scrap. With that said I don't know 100% what grade it would be from Boardsort, but my guess is Low Grade Telecom because of the heavy connector and lots of plastic memory slots. If it didn't have those it "could" fall into a multi socket mother board large or small depending on the size of the CPUs.
PostPosted: Fri Dec 03, 2021 1:01 pm
My Bad
261531620_3182026338718492_1971042842559724088_n.jpg [ 273.46 KiB | Viewed 3490 times ]
260437459_1038544223611291_5453033931234889806_n.jpg [ 423.19 KiB | Viewed 3490 times ]
PostPosted: Fri Dec 03, 2021 1:02 pm
Here is some more
260804540_585715332497637_7610751587097995728_n.jpg [ 157.64 KiB | Viewed 3490 times ]
262291149_432065758631053_6432321541027291543_n.jpg [ 284.38 KiB | Viewed 3490 times ]
PostPosted: Fri Dec 03, 2021 1:37 pm
I take it the CPUs are not removable?
