It is currently Wed Oct 28, 2026 5:34 am
 Post subject: Board ID #2 12-14-2021
PostPosted: Tue Dec 14, 2021 3:42 pm
Here are some boards. Have some front and back photos. Most are probably high peripheral, but wasn't sure if any of these could slide into low telcom.
Anything to be removed on board 3?
Thanks
PostPosted: Tue Dec 14, 2021 10:16 pm
My internet is being extremely slow right now... pictures aren't loading very fast.
1) low telco seems possible, especially if the main port has gold pins
2) low telco at least as is; see if the card slot can be removed. If it can you're easily at high telco, may still be even if it can't be removed.
3) As is with all the metal I'm leaning high peripheral; if you can get the steel off, even with the plastic, you should clear low telco.
4) Back to the internet issues, high peripheral at least can't load the picture fast enough to tell if it can go higher.
5) High peripheral
PostPosted: Wed Dec 15, 2021 4:22 pm
4) looked again now that I have decent internet, looks like there's some screws and plastic that could still come off. The antennae might also be a piece of steel, not sure from the photo. Probably okay high peripheral as is. Not sure if removing the mentioned parts would help improve the grade.
PostPosted: Thu Dec 16, 2021 12:10 pm
Thanks for the help. Much appreciated
