It is currently Mon Jun 29, 2026 11:10 am
PostPosted: Fri Dec 10, 2021 2:51 pm
are these some kind of batteries / are they safe to open ?
PostPosted: Sat Dec 11, 2021 5:33 pm
Not 100% sure what these are based on the picture. Power relays, transformers??? Not capacitors, definitely not batteries. Depending on what it is either take apart at your own risk or definitely don't take apart...
¯\_(ツ)_/¯
PostPosted: Thu Dec 16, 2021 10:46 pm
It's a relay
Yes they are safe to open, whack it with a hammer
PostPosted: Fri Dec 17, 2021 1:05 am
If they’re as flat as they appear they’re likely relays and then hammer time sounds… er… fun? I guess?
PostPosted: Fri Dec 17, 2021 9:45 am
"If they’re as flat as they appear"
here is side view. They are magnetic, I just wondered if they might have mercury or something inside. I will investigate later.
PostPosted: Fri Dec 17, 2021 10:13 am
Mystery solved
PostPosted: Fri Dec 17, 2021 5:18 pm
And that, as was said, “is the rest of the story”
PostPosted: Fri Dec 17, 2021 11:56 pm
The lack of depth made it tricky, soon as the side picture was there I knew you were safe, some copper, some steel and maybe something special in the contacts :D
