It is currently Tue Sep 22, 2026 6:58 am
 Post subject: Need help to identify
PostPosted: Fri Jan 14, 2022 6:14 pm
Im going to be sending these i want to sort them out correctly. Thanks in advance.
PostPosted: Sat Jan 15, 2022 4:13 pm
Could you separate the photos of boards or number them, as it is hard to say which is which when answering?
PostPosted: Sat Jan 15, 2022 4:46 pm
I'll get things started so that you can get some of these out of the way.
I believe top image is a repeat Lost answered elsewhere.
Looks like this board handled large amounts of power and the blue connectors may have silver plated connectors; I'd guess low peripheral.
All RAM except the three PCI cards in the upper right corner. You will want to remove the heatsinks from everything to get the best price. Once that's done Gold fingered RAM and Clean GFC.
(agree with PickleJar) You have multiple repeated boards within and across the remaining photos. If you have multiple of board X then you can have frontX and backX in a picture but there's no reason to have W, X, X, X, X, Y, Z in a picture. You should also remove display screens and wires from your boards for the best grade.
The very last pic, the yellow components look like clocks, if that's what they are they need to be removed.
