It is currently Thu Jul 30, 2026 1:07 am
 Post subject: Board identification
PostPosted: Mon Jan 24, 2022 6:57 am
I am trying to understand what makes a board each different type. Telecom, peripheral, how removing something upgrades the board.im trying to learn because I have alot of e scrap to get through. Once I get a understanding I wont have to ask so many questions. I appreciate you all for taking time to help. I apologize for there being so many.
 Post subject: Re: Board identification
PostPosted: Wed Jan 26, 2022 11:12 pm
1. Low telecom, but you will need to take it out of the housing
2. My guess will be all midgrade
3. Both low telecom
4. Is 5 the other side of the same board? If so, high peripheral. If not, midgrade.
5. High peripheral
6. High telecom
7. High peripheral
8. A. midgrade, B. High peripheral, C. Gold finger card D. Backplane
PostPosted: Thu Jan 27, 2022 8:50 am
You won't make much headway as long as you are staring at a pile of mixed grade boards. Pick out one board, look it over, then holding it as reference, go thru your stacks, separating out those that look similar to the one you are holding.
Once you have those out of the pile, and separated, do the same with another board, until you have your collection sorted into boards that look a little bit alike. Don't worry about identifying them at this stage. You can learn the fine points of calling them George or Bill or Sue after you get which family they are in.
Low Grade is usually anything with a brown board. The board is simply a holder for the components, and usually is drilled thru and has solder connections on the back. These have low grade components, not many of them, and heavy transformers, large capacitors, and large aluminum heat sinks which add a lot of weight to the board, but no value as precious metals. Usually not worth shipping because of cost/weight/return ratios. Alternatives are deliver in person to Boardsort along with quality boards, or strip the transformers for the copper and aluminum for sale at your local yard.
Mid Grade is similar to Low grade, in that it has a lot of heavy iron/copper coils/transformers, heat sinks, and capacitors. The obvious difference is the mounting circuit board is Green. This means the board is composed of several layers of fiberglass cloth, with a layer of copper tracings which connect the various components, so there is copper value inside the bare board. A green board can have some ICs and other electronic components and still be mid grade if it has the heavy components. Usually not enough components to upgrade it to low peripheral even if the heavy components removed. As to shipping, again not practical, but good for in person delivery. Note: if you are scrapping industrial/commercial equipment, often you will find a hybrid board that has both a power supply type end and a more heavily populated end, in which case it is profitable to remove the heavy components and ship.
Low peripheral is sort of limbo land. Not a lot on the green board to make it valuable, but not anything to give it excessive weight, ie, no transformers, large coils, not many IC chips.
High Peripheral is almost a Motherboard without the CPU chip. It will have pretty good electronic component populations: IC chips (usually soldered) flat packs sometimes, diodes, transistors, usually a lot of components. Also it should have some connectors, hopefully gold pin. May or may not have edge connectors like a Motherboard. Actually at todays prices, some High Peripheral are worth more than recent Motherboards.
I would suggest you sort out the above categories from the main pile and spend a few minutes recognizing them...low and mid grades easy. It is too daunting to try to make sense of the whole range in one pile. Once you have these boards separated, the task will seem less overwhelming. I will not go into the better grades in this discussion.
PostPosted: Sat Jan 29, 2022 12:32 pm
I just want to take a second and thank Meowpher The Ninth. This is an awesome beginner guide! If I had read something like this when I stared out, it would have helped me immensely!!! Thank you Meowpher, this rocks. I look forward to reading the follow up. ;)
PostPosted: Sat Jan 29, 2022 6:11 pm
malphorian1973, there is a ton of information in the forum! Unfortunately, it can be hard to find the good stuff but..!
If you have time to kill I would suggest doing a search with Lostinlodos in the author box and then go to the bottom of the results and click on page 922 (yeah he's posted that much!) and just read from the past back to the present. Some of those initial posts he's still learning but it's a wealth of information.
I've been considering going back through some of my posts and adding a search string that I can use to find some of my more useful posts more easily and in turn link back to them when appropriate.
PostPosted: Fri Apr 01, 2022 3:04 pm
I agree I probably should not have tried to put that many on one post I apologize but appreciate all the input the wealth of knowledge that you just give me in the initial response I appreciate more than you can know cuz it really helped me after sitting back and reading it I've read it several times going through all of these boards finally got enough to get a couple of shipments out the board sword I'm a little too far away to take it in not really worried about low grade and mid-grade board so probably just process them here all the high-grade stuff is what I want to send up to them I'm just doing the best I can to figure it out and I'll definitely check out that other person's post
PostPosted: Sat Apr 02, 2022 6:38 pm
You are absolutely correct marked. I was going to say something similar about the forum. And to any and all beginner's, the biggest piece of advice I can give is to read as much of these posts as you can! Especially the ones from names that you see answering posts alot. These guys are very smart, and they know their shit! I have learned so much in the past year from these guys, it's amazing! Not just about E-scrap, but electronics in general. I have said this many times, read, read, and READ!!! Thanks guys, you are all aces!
