It is currently Sat Nov 07, 2026 9:15 pm
PostPosted: Sun Jan 30, 2022 6:42 pm
Hi all, thanks for having me. Been out of the game for a bit but now back in full swing. These came out of an old 1980's Data General server. The ones that are 5' tall or so. Would I benefit from pulling certain things or just leaving as is? The pins on the ceramic chips have gold legs/pins. They look like CNC boards on the boardsort site but obviously they are not.
Also, is there such a thing as silver plating on older boards? These almost look like silver traces.
PostPosted: Sun Jan 30, 2022 7:59 pm
1) High telco
2) Gold Cap Chip Board; I'd go ahead and snip off the white wires
3) Gold Cap Chip Board; trim wires
4) Gold Cap Chip Board; trim wires and the aluminum (and transistors) can probably stay but could be removed if you need to for shipping
5) High telco; trim wire
6 front and back?) Anything is possible; the texture of the tracings look like there's mostly solder (which could have silver) on this board. Being from the 80s I would expect there to be some tarnish if it were high percentage of silver. As is I'm leaning low grade.
7-8) Tracings look cleaner here but same notes from 6. It looks like a lot of these components may be screwed down in a way that they can be removed more easily. Even if you do remove anything I'm again leaning low grade on these two.
PostPosted: Sun Jan 30, 2022 8:51 pm
Thank you for your advice marked141. So much to relearn.
PostPosted: Mon Jan 31, 2022 10:55 am
Question: can the gold fingers be trimmed on the "gold cap chip boards" without affecting the grade?
PostPosted: Mon Jan 31, 2022 4:26 pm
Except for #4, I think the fingers can be trimmed without negatively impacting any of the boards. If you didn't pull the components on 4 I mentioned before I would definitely leave the fingers to offset any chance of the aluminum bringing the board down a grade.
