It is currently Tue Sep 22, 2026 7:53 pm
PostPosted: Thu Feb 17, 2022 9:11 pm
The oddball listed as number one it's a component that came off of circuit board listed as number 2 circuit board had an absolutely massive 2 lb extrusion aluminum heatsink with 4 very large and removed aluminum capacitors (were mounted on the right side of board two in picture two) it was a control unit for a large rooftop AC motor.
The oddball has a sort of gold pins coming through two way gold plated non-magnetic rectangle with some sort of rectangular chips on top in a gel-like substance??? it was clearly the heart of the processing unit of scrap that processing unit would have went for four hundred bucks on eBay had I not destroyed it live and learn didn't look it up till I saw this totally weird covered in gold... Thing pictures 3 4 and 5 give details.
Board 2 had the weird #1 thing mounted on 4 long pins, seems silver-plated on the front?
Board 3 is off a TV had tHe DLP ceramic chip mounted on it seen in picture two looks gold plate
Board four five and six came off the largest Sony cathode ray tube semi flat screen stream 97.. board 6 address what do I do with all these TV boards with a bunch of connections on them. Board four and five have gold pin connectors Linking them to a loe-mid board you can see in the background... 5 is copper plate 4 has a lot of shiny silver dots...
I've got a lot of boards categorized but these ones are just eluding me where to put them thank you for your time
PostPosted: Tue Feb 22, 2022 11:42 pm
I'm going to preface this with, the pictures aren't great. I think the biggest issue is they're out of focus, The lighting causing the bright spot on board 5 isn't helping but I think the focus is worse. Make sure you have even lighting (avoid camera flash if possible) and take more photos of fewer boards if you have trouble getting a quality image of multiple boards.
1) The piece you pulled apart with a gelatinous material on it, is probably some type of transistor, I have a topic posted in the general section that I'm hoping gets answered at some point. For now I don't know.
2) Midgrade
3) High peripheral (the board) DLP Ceramic (the chip)
4) I'm leaning low peripheral (possibly can go high periph)
5) High peripheral
6) Low peripheral
PostPosted: Wed Feb 23, 2022 9:05 pm
Lost replied see this thread:
viewtopic.php?f=3&t=21315
PostPosted: Sat Feb 26, 2022 4:35 pm
Can you link to that link for me so I can follow up. Been a bit busy with multiple projects and my response rates are slipping.
