It is currently Thu Sep 24, 2026 10:14 pm
PostPosted: Tue Mar 01, 2022 1:13 pm
Trying to grade telecom boards have a few hundred boards. I get low grade will be ones with transformers and such but are there multiple other grades? And does the aluminum plate need to be removed? Thanks in advance
PostPosted: Tue Mar 01, 2022 5:44 pm
I would remove the aluminum plate, grounding bar on the back and fiber jumper. I think it will be high grade telcom at least, but That could be a gold edge board. I'm not sure.
PostPosted: Thu Mar 03, 2022 6:11 pm
I still need clarification on cnc boards before I can suggest things go in that grade.
To me the population on this board seems fairly thin, it has good stuff on it, but I'm leaning low telco once you get all the suggested parts removed.
PostPosted: Fri Mar 04, 2022 3:13 pm
Can you get all the suggested parts removed and post a new pic? I emailed Chris for a little clarification.
PostPosted: Sat Mar 05, 2022 4:23 pm
I will pull the suggested parts and post a new pic. Thanks for the help
PostPosted: Sat Mar 05, 2022 8:08 pm
I need help with these as well they are approximately 14x10 inches. Not much in the way of chips but they have nice double sided gold fingers and flashing on both sides.
PostPosted: Sun Mar 06, 2022 10:32 am
Here is another is the other type of this board.
PostPosted: Mon Mar 07, 2022 11:39 am
Here is the board cleaned of metal
PostPosted: Mon Mar 07, 2022 11:47 am
I want to be sure and send the right boards in the right category as it cost me about 90 cents a pound to ship boards so I can’t afford to ship any that would be below motherboard prices. Can you help me identify the boards I have posted and these too. Thanks in advance.
PostPosted: Mon Mar 07, 2022 11:48 am
Here is another
