It is currently Thu Jul 30, 2026 7:38 pm
 Post subject: Please grade
PostPosted: Mon Mar 21, 2022 3:32 pm
Please grade and should I remove the red circled items for upgrade?
 Post subject: Re: Please grade
PostPosted: Tue Mar 22, 2022 12:44 pm
After removing all the heatsinks, I think you should have no problem getting high grade peripheral on these.
PostPosted: Tue Mar 22, 2022 2:46 pm
What about the transformer thing will it need removed also?
PostPosted: Tue Mar 22, 2022 5:46 pm
Not on these. That trans is small (doesn't add much weight and that's what matters) and the "good" population is enough to counter it. It's pretty much almost always a "good" weight vs "bad" weight equation. Were the "good" weight = IC's, Tantalum capacitors, monolithic capacitors, and other PMG laden materials. And the "bad = plastics, metals like aluminum, steel, Nickle, copper, ect. and other "junk" found on the pcbs. I hope this helps. Have a good day and happy recycling!
