 Post subject: classification please
PostPosted: Wed Aug 12, 2015 3:32 pm
Have no idea on this one, seems to be more than just a backplane board? Any help would be appreciated!
PostPosted: Thu Aug 13, 2015 11:24 am
My first guess is telco if the top right of the pic that rectangle has dozens of small tightly packed gold pins.
Otherwise it is probably backplane
You're exceeding well past the contents of a standard mobo.
PostPosted: Fri Aug 14, 2015 10:42 am
I would consider it as a dual small socket motherboard given the appearance of two soldered CPU chips on the board.
PostPosted: Fri Aug 14, 2015 12:08 pm
Kind of a fluke board.
Kgryczan makes a good point.
It's definitely a sub shelf breakout board with its own pci controllers.
Sort of like a jumbo gigantic pci card.
Best solution in this case is probably to send an email to Chris/boardsort with a photo and ask directly.
PostPosted: Fri Aug 14, 2015 12:12 pm
The deciding factor will rest on the boards flashing and if that rectangle is a pg65 (gold pin) connector. So make sure to get the best quality photos you can take of the board and the pin connector.
Fyi pg65 connectors are ALWAYS gold plated nickel/Mg alloy -- not steel. So if you have a small magnet see if it sticks.
