It is currently Mon Jul 27, 2026 9:57 pm
 Post subject: Gold Pin Guidance
PostPosted: Fri Apr 08, 2022 4:10 pm
I do see that BoardSort currently buys gold pins, and also see that their focus filter is “blue”, indicating that there may be more complex issues. I currently have close to 6 pounds of “various” gold pins. I started pulling them from day one of e-scrapping and have always just thrown all of them into the same bin. Is that acceptable for BoardSort, or do I need to do anything more with them? Obviously I am at this point not going to go through, pin by pin and separate them into several categories or clip some of them down after checking each one as this is obviously THOUSANDS of pins. Thank you for any help or advice.
 Post subject: Re: Gold Pin Guidance
PostPosted: Fri Apr 08, 2022 6:49 pm
Your fine.
The issue with gold pins is that you’re just about always better off with the value of the item pins intact rather than removing pins alone.
PostPosted: Sat Jul 09, 2022 10:56 am
Is it safe to assume the hard disc drives are not gold pins? I tried extracting gold from them through chemical baths but either didn't get anything or messed it up.
PostPosted: Sat Jul 09, 2022 2:59 pm
Hard drives have some gold pins. The pins on the controller board for the protocol port.
And the pins in the internal relay connector at often gold as well.
PostPosted: Sat Jul 09, 2022 6:38 pm
I meant the little hard disc drives not hard drives
PostPosted: Sat Jul 09, 2022 6:39 pm
I think that's what you call them, the non floppy drive lol
PostPosted: Sat Jul 09, 2022 7:15 pm
If you are talking about the round platters inside a hard drive. No. With very few, very old, exceptions there’s no gold.
PostPosted: Sun Jul 10, 2022 12:15 am
Not hard drives and not cd rom/DVD. The old square disc you used instead of floppy disc. That drive. I don't have a pic of 1 but can get 1 tomorrow. They typically have a brown board with next to nothing on them. The pins look gold
PostPosted: Sun Jul 10, 2022 12:24 am
Ah, the 3.5 inch micro floppy.
The pins are definitely gold. Don’t remove them, floppy drives boards go as peripheral boards.
PostPosted: Sun Jul 10, 2022 10:29 am
That's what they are called lol. Thank you
