PostPosted: Sun Apr 24, 2022 5:42 am
Hey I'm sure these have been posted before but the search feature does not work too well so I cant find anything on them without some serious deep digging.
File comment: These long skinny boards (this one is broken in half) Has anyone sold these to boardsort? Do they still go as clean gold finger or get downgraded due to smaller amount of gold?
File comment: The connectors from hard drives. Gold pins with the wire. Would these just be gold connectors?
PostPosted: Sun Apr 24, 2022 2:35 pm
I think you're looking at low peripheral on the long board. The gold fingers on there are vastly outweighed by the board and may not even have much gold on the fingers. Gold finger cards are generally PCI cards or other similar connectors that expand the capabilities of your computer or server and have a relatively thick layer of gold. I had several posts with gold finger cards:
Here
Here
Here and...
Here
None were graded as Gold Finger Cards even though most of them have them.
Unless someone beats me to it I'll have to look and see if I can find anything on those HDD parts. Initial thought is don't tear those off if you can help it, the other end has a small chip and left intact you could probably get a better grade whole.
PostPosted: Mon Apr 25, 2022 10:18 am
Based on a couple of Lostinlodos' previous posts I'm guessing low peripheral if left intact, mixed wire if no gold visible and if gold is visible then probably okay as gold connector ends.
