 Post subject: Board ID 4-22-2022 #1
PostPosted: Fri Apr 22, 2022 5:34 pm
Hello. Here are 7 boards, and my guess as to what they might be. I appreciate the help.
1) Low Peripheral - Remove Transformer and Coax Shield
2) High Peripheral
3) Mid Grade
4) Connector End
5) Low Grade SATA Hard Drive?
6) Low Peripheral?
7) Low Peripheral or Midgrade?
Thanks
PostPosted: Fri Apr 22, 2022 11:07 pm
1. I agree, low peripheral, remove the transformer and the shield
2. Low peripheral
3. High peripheral if that is a laptop touchpad, low peripheral otherwise
4. Connector end
5. Low grade HDD board
6. Midgrade
7. Not sure, my guess is low peripheral
PostPosted: Sat Apr 23, 2022 12:57 am
1) I'd say low peripheral as is; though I would personally try to remove the broken plastic I don't think it's necessary. That shield doesn't appear to be a shield I think that whole component will come off if you try to take the metal (I could be wrong but that's what I've seen before).
2 & 3) Agree
4) I feel like I missed some comments on connector ends at some point so not sure on this one; I was leaning more toward midgrade.
5 & 6) Agree
7) Not sure; this is one of those where I'd throw it in midgrade because I'm not sure it can make it to low peripheral and it would just sit around unsorted for weeks...
PostPosted: Mon Apr 25, 2022 10:19 pm
#7 I'm not too certain either. I just said low peripheral because that is what keypads with immersion gold are usually graded as, this board has strips of immersion gold.
